Regarding any consideration of a proposal for an RP and associated calculator to be recommended for balloting to the entire TMC membership, there must be a "final" draft of source files presented in the Task Force public session and discussed before any motion for a recommendation can be made and voted on my members of the Task Force for the record. A calculator (presumably in Excel with macros) would need to be tested beforehand in order to allow for a proper evaluation at the public session. In addition to a what we would presume would be a model methodology for identifying/evaluating EV TCO for a fleet, the RP proposal would also need to serve as the "user manual" for the calculator.
Is there enough time to reasonably get to a final draft stage before Annual Meeting, or would a better target be the 2026 Fall Meeting? Since the balloting and appeals processes take 12 months prior to publication, having everything finalized beforehand make it more likely for the version proposed to make it though the first time around.
Disclaimer
NOTICE: This e-mail message and any attachments to it contain confidential information and are intended solely for the use of the individual(s) or entities to which it is addressed. If you are not the intended recipient, or an employee or agent responsible for delivering this message to the intended recipient, you are hereby notified that you are prohibited from reviewing, retransmitting, converting to hard copy, copying, disseminating, or otherwise using in any manner this e-mail or any attachments to it. If you have received this message in error, please notify the sender by replying to this message and delete it from your computer.
Original Message:
Sent: 1/7/2026 10:20:00 AM
Subject: 01/05/2026 Meeting minutes
good morning all please see attached for this past Team meeting minutes. Thanks
Chris Perry
Director, Technical Support & Training
FlowBelow Aero, Inc.
Round Rock TX
